NI Linux Real-Time Discussions
Unable to self-reboot when the device has no IP?
On current versions of LVRT for Linux, the rtexe is not an exectuable, it's just a resource loaded by the LVRT executable /usr/local/natinst/labview/lvrt. That's the executable on which you need to run setcap. This is now documented in a KB, see http://ae.natinst.com/public.nsf/webPreview/3C1FBAB957A6370286257E1B0066B98E?OpenDocument
Message 11 of 14
(1,644 Views)
A very important note:
When using setcap, be sure to provide all of the capabilities needed! If there are already capabilities on the binary (as there are), you will be overwriting the existing capabilities.
admin@calamyne:~# getcap /usr/local/natinst/labview/lvrt
/usr/local/natinst/labview/lvrt = cap_net_bind_service,cap_ipc_lock,cap_sys_rawio,cap_sys_boot,cap_sys_nice,cap_sys_time+ep
admin@calamyne:~# setcap cap_net_admin=ep /usr/local/natinst/labview/lvrt // BAD! Don't do this
/usr/local/natinst/labview/lvrt = cap_net_admin+ep // We lost capabilities! LVRT won't work correctly anymore!
admin@calamyne:~# setcap cap_net_bind_service,cap_ipc_lock,cap_sys_rawio,cap_sys_boot,cap_sys_nice,cap_sys_time,cap_net_admin=ep /usr/local/natinst/labview/lvrt
/usr/local/natinst/labview/lvrt = cap_net_bind_service,cap_net_admin,cap_ipc_lock,cap_sys_rawio,cap_sys_boot,cap_sys_nice,cap_sys_time+ep //Fixed.
Message 12 of 14
(1,644 Views)
Hmm, that document link is gone...
Ryan Vallieu CLA, CLED
Senior Systems Analyst II
NASA Ames Research Center
Message 13 of 14
(1,140 Views)
It probably was never there to begin with. ae.natinst.com is a non-public internal support site.
I don't actually know what's supposed to be documented here... lemme pull some strings.
Message 14 of 14
(1,121 Views)
