NI Linux Real-Time Discussions
取消
显示结果
搜索替代
您的意思是:
Setting Serial Port Configuration on Startup
已解决!
转到解答
Hello All!
I just posted this question as a comment on this tutorial page, but I feel like that may get overlooked, so I am replicating it here.  Sorry for the double post!
I am running into a conundrum and I was wondering if anyone had some insight.  For background, my app requires remote access to the serial ports on my cRIO from the host, so I have configured ser2net (successfully) to forward them over TCP/IP.  Using the tutorial above as a guide, I was able to get ser2net to start on boot, which is fantastic.
The only issue I am having is trying to configure the serial port settings at boot.  This is a slightly different use case from the above, since I don't want to start a daemon, but simply run a few commands.  I use stty to set my serial configurations, and have incorporated it into the startup script as shown below.  (important piece in bold)
#!/bin/bash
NAME="Ser2Net Daemon"
DAEMON=/usr/sbin/ser2net
ARGS=" -n"
USER=admin
PIDFILE=/var/run/ser2net.pid
do_start() {
    /sbin/start-stop-daemon --start --pidfile $PIDFILE \
        --make-pidfile --background \
        --chuid $USER --exec $DAEMON -- $ARGS
do_stop() {
/sbin/start-stop-daemon --stop --pidfile $PIDFILE --verbose
case "$1" in
  start)
echo "Starting $NAME"
/bin/stty -F /dev/ttyNIRIOslot2port0 115200 ixon
/bin/stty -F /dev/ttyNIRIOslot2port1 115200 ixon
do_start
  stop)
echo "Stopping $NAME"
do_stop
  restart)
echo "Restarting $NAME"
do_stop
do_start
echo "Usage: $0 {start|stop|restart}"
exit 1
esac
exit 0
Now, if I test this after installing the script (by entering "/etc/init.d/ser2net.startup start" in the shell), this works fine.  However, if I reboot, the commands seem to do nothing, and the port config stays default.  To me, this means the syntax, etc. must be right, but somehow doing it at startup is causing issues.
Does anyone have any ideas why these commands would fail during startup but not during normal operation?  Is there a way to debug what is happening on startup?
Thanks in advance!
Drew
Drew T.
Camber Ridge, LLC.
1 条消息(共 7 条)
10,922 次查看
If I'm understanding your post correctly, the script might not be failing -- it might not be running at all. You may just need to add a missing symlink. Putting a script in init.d doesn't tell the system when to run it. To do that, you need a link to it in /etc/rc<level>.d/. The link name includes a prefix S (for start -- or K for kill, run on shutdown) and a sequence number. An example for your case might be /etc/rc5.d/S50ser2net.startup -> /etc/init.d/ser2net.startup. The update-rc.d tool can do all this for you, see http://manpages.ubuntu.com/manpages/hardy/man8/update-rc.d.8.html
0 项奖励
2 条消息(共 7 条)
10,121 次查看
Scot,
Thanks for the quick reply.  I realize I wasn't very clear about this part, but I know the script runs because ser2net comes up as a daemon.  I can communicate with the COM ports remotely and see the process using ps | grep ser2net.
Any other thoughts?
Thanks!
Drew
Drew T.
Camber Ridge, LLC.
0 项奖励
3 条消息(共 7 条)
10,121 次查看
For clarity, I ran update-rc.d, and see K20ser2net.startup in /etc/init.d/rc1.d.
Drew T.
Camber Ridge, LLC.
0 项奖励
4 条消息(共 7 条)
10,121 次查看
解答
接受人 Drew_T
One reason could be that the script runs before the hardware is up.
The symlinks created with update-rc.d that start with K are called to stop a daemon (e.g. at shutdown). Can you list where the 'S*ser2net' symlinks are? Or list the update-rc.d command you are using?
Really this sort of hardware configuration belongs in a udev rule instead. You can create a udev rule that matches /dev/ttyNIRIO* in /etc/udev/rules.d. Make the rule run on the "add" action and invoke the required stty command from there. This will guarantee that the stty configuration is applied after the hardware is up.
0 项奖励
5 条消息(共 7 条)
10,121 次查看
Excellent, this is exactly the feedback I was looking for!  Being a Linux newcomer, I don't know the "right" ways to do things yet.
My symlinks are below:
admin@cRIO-9035-A:~# ls /etc/rc*/*ser2net*
/etc/rc0.d/K20ser2net.startup  /etc/rc1.d/K20ser2net.startup  /etc/rc2.d/S20ser2net.startup /etc/rc3.d/S20ser2net.startup  /etc/rc4.d/S20ser2net.startup  /etc/rc5.d/S20ser2net.startup /etc/rc6.d/K20ser2net.startup
I am just using the standard update-rc.d command below:
/usr/sbin/update-rc.d -f ser2net.startup defaults
I will look into the udev rule, as this seems more like the correct way to go.
Thanks for the help!!
Drew
Drew T.
Camber Ridge, LLC.
0 项奖励
6 条消息(共 7 条)
10,121 次查看
Ding, ding, ding! We have a winner!
I added the file below to /etc/udev/rules.d and the ports now configure on boot.  Thanks for the awesome help Gratian!  This community rocks!
KERNEL=="ttyNIRIOslot[0-9]*port[0-9]*",        ACTION=="add", \
        RUN+="/bin/stty -F /dev/$name 115200 ixon"
Drew T.
Camber Ridge, LLC.
0 项奖励
7 条消息(共 7 条)
10,121 次查看
