NI Linux Real-Time Discussions
MySQL InnoDB engine
Hi BradM,
The reason for me looking into ways on accessing a MySQL database from a NI Linux RT cRIO is that I have already made some investment/development into using MySQL from a Windows OS and the goal is hopefully to reuse that implementation.
Marcus
______________________________________________
Marcus Törndahl (System Architect)
Message 11 of 15
(1,516 Views)
Hi Marcus,
What I was attempting to clarify is whether or not you intended on, for example, moving the actual database stores to your target (in which case, the InnoDB support makes sense) or if you simply wanted client access from the target to your DB server on your Windows PC (in which case you don't care about the storage driver, you simply care about the communication standard, e.g. ODBC).
Disclaimer: I am not a db admin, I've just played around with one, including "remote" access from a container
Message 12 of 15
(1,511 Views)
Hi BradM,
Well my goal is to move the database to a more suitable location for the test system I'm building. As this test system will be offline I need the database to be located in the system. One part of the system is the NI cRIO 9030 with NI Linux RT which I am investigating the possibility to host the MySQL server. In combination to the server installation I also need to find the communication solution to the server and preferably to be able to reuse a present ODBC-communication extensively tested and working solution.
Marcus
Message 13 of 15
(1,507 Views)
Ah, this clarifies why you were asking about both. So, it seems that either case (local server/store on the cRIO and remote access to an external server) should work fine. You should be able to use the existing stores on the controller so long as they are in InnoDB/XtraDB format (I have not tested this).
Message 14 of 15
(1,499 Views)
Sorry but could you explain in more detail?
Message 15 of 15
(1,495 Views)
