‎01-24-2018
04:09 AM
- last edited on
‎06-20-2025
02:18 PM
by
Content Cleaner
I was wondering if anyone knew which files i need to blacklist to keep system time/date whne performing a RAD (https://www.ni.com/en/support/documentation/supplemental/12/archive-of-the-real-time-application-dep...) install?
Or just in general where system time is kept.
‎01-24-2018 11:38 AM
Hi Mrmas,
Which controller are you using? Most cRIO controllers have an RTC that holds the time for the system (which should not be affected by a RAD install, although I am less familiar with how RAD works)
‎01-25-2018 02:33 AM
I am using a sbRIO 9627. I have seen the time turned back weeks/months when installing disc images via RAD. They seem to go back to the same point, though not specifically linked to when the disc image was created. I figured mabye the complete disc image covered the system files which keep the time.
‎01-31-2018 03:50 PM
It seems that the sbRIO 9627 has an RTC, so I'm not quite sure why you're seeing the behavior that you are. Just as a sanity check, you're seeing the time being set back (but not too far back, e.g. 1970 or near the UNIX epoch), is that right?
