NI Linux Real-Time Discussions
Is it possible to install an NI driver on a remote cRIO using SSH?
Hi all,
I would like to know if it's possible to install NI System Configuration on a remote cRIO 9031, without using MAX and using SSH for example?
Many thanks,
(3,277 Views)
Accepted by KeyHood
There is not a supported way to install NI software like System Configuration on a target without using NI MAX or the System Configuration API. What is the end goal here? If the goal is simply to programmatically install software remotely, this can be done with the System Configuration API.
(3,257 Views)
Thanks for your reply.
It's the request of a customer. He needs to install the NI System Configuration on a cRIO 9031 which is in a production site. He wanted to know if it's possible to install it remotely.
(3,245 Views)
