NI Linux Real-Time Discussions
Embedded UI - Unicode
Is there a way to display Unicode text on an NI Real-Time Linux Embedded UI front panel using standard LabVIEW string controls or indicators? I have performed my usual tricks of getting this to work in a Windows environment but so far have been unsuccessful with NI's Real-Time Linux.
Current NI Real-Time Setup:
Linux 3.14.46-rt46-3.5.0f0 x86_64
LabVIEW Real-Time 15.0.1
XFCE version 4.10
(3,211 Views)
I believe that the LVRT Embedded UI (which is based off of the ageing LabVIEW Linux and UNIX UI support code) does not support Unicode, either in the Xlib that it uses nor how the code is actually written. You should work with your local sales rep and let them know your use-case, as that's one of the driving factors for when/if things are worked on (customer feedback)
(3,200 Views)
Also this subject was discussed 2 years ago, I am running into exactly the same problem now. Is there any solution?
(2,494 Views)
