NI Linux Real-Time Discussions
Duplicate a compactRio-9068 setup to deploy it to the another 9068 controller
I have a compactRio-9068 controller which is setup with following configuration:
1. Installed Labview Real Time and other necessary SW through NI MAX.
  2. Manually installed one library package from opkg  (libusb1.0)
  3. Placed an init script at runlevel 5 and copied an executable to a specific location on local drive.
4. Added NFS share mount request line  in /etc/fstab
5. static IP address settings for both eth ports.
I would like to deploy another compactRio-9068 chassis with similar configuration. Is there a way to duplicate the whole setup on one compactRio chassis to another chassis without requiring to go though step by step manual setup process?
WillsG
(4,003 Views)
Accepted by WillsG
Yes, we have a replication and deployment utility for this purpose: https://www.ni.com/en/support/documentation/supplemental/12/archive-of-the-real-time-application-dep...
Cheers,
Matt Pollock
(3,465 Views)
Thank you, MattP.
This seems verys useful. I will explore it in more details soon.
--WillsG
(3,465 Views)
