NI Linux Real-Time Discussions
Detecting a watchdog reset
The question is simple: is there a way to detect if a system reset was triggered by a watchdog event instead of power-on-reset?
Luca
Message 1 of 14
(10,087 Views)
Just for clarification, I would imagine you are interested in knowing from a LVRT application on the target, is that right?
Message 2 of 14
(8,730 Views)
Yes, the idea is to be able to do a post-event log and differentiate from a power-on-reset. Otherwise it's impossible to know if the reset was caused by the WDT or a problem in the power supply or the O.S.
Luca
Message 3 of 14
(8,730 Views)
I don't know if there's a friendly UI way to do that, but you can use the System Exec.vi utility VI to read the "reset_source" pseudo-file (on my myRIO and cRIO 9068, it is located at /sys/devices/amba.0/e0004000.i2c/i2c-0/0-0040/reset_source).
Check it first on the serial console or SSH (or monitor/keyboard if we're dealing with one of the newer x64 cRIOs), then wire up the System Exec with the same command you ran and check for "watchdog" being returned from reading the file.
Message 4 of 14
(8,730 Views)
Thanks. That is exactly what we were looking for!
Luca
Message 5 of 14
(8,730 Views)
We are having problems with file permissions. From SSH everything is fine, but from the application we cannot read the file, since it has permissions 400 (only owner can read it).
Any workaround?
Luca
Message 6 of 14
(8,730 Views)
A shorter and less device-specific path to it is /sys/bus/i2c/devices/0-0040/reset_source
Message 7 of 14
(8,729 Views)
Accepted by topic author sirluke
Bleh. Not an easy way. You could add a startup script to check and change the permisisons of the file.
This is a pretty resonable resource on writing and using a startup script: Tutorial: Installing Startup Scripts on NI Linux Real-Time
You'd want the script to use ls -l /path/to/file to check the permissions and chmod +r /path/to/file if the permissions are wrong. (note: you could also use chmod 444 or chown lvuser, but just use the +r)
Message 8 of 14
(8,730 Views)
Great. It works perfectly!
Luca
Message 9 of 14
(8,730 Views)
Luca
Great to hear! Sorry it wasn't quite as friendly or UI-centric a way to get to where you needed to be, but we got there.
Message 10 of 14
(8,730 Views)
