 bhpa
			bhpa
		06-19-2018
		06:15 PM
 - last edited on
		10-08-2025
		07:47 PM
 by
		 Content Cleaner
			Content Cleaner
Hi all,
I would like to install inotify-tools on a sbRIO-9627 controller.
I have attempted to install with opkg, only to get this result:
admin@sbRIO-9627:~# opkg install inotify-tools Unknown package 'inotify-tools'. Collected errors: * opkg_install_cmd: Cannot install package inotify-tools.
After following the instructions found here, I am now stuck at this point:
./configure --prefix=/usr && make && su -c 'make install' checking for a BSD-compatible install... ./install-sh -c checking whether build environment is sane... yes checking for a thread-safe mkdir -p... ./install-sh -c -d checking for gawk... gawk checking whether make sets $(MAKE)... yes checking whether make sets $(MAKE)... (cached) yes checking for gcc... gcc checking for C compiler default output file name... configure: error: in `/usr/src/inotify-tools/inotify-tools-3.14': configure: error: C compiler cannot create executables See `config.log' for more details.
config.log:
admin@sbRIO-9627:/usr/src/inotify-tools/inotify-tools-3.14# cat config.log
This file contains any messages produced by compilers while
running configure, to aid debugging if configure makes a mistake.
It was created by inotify-tools configure 3.14, which was
generated by GNU Autoconf 2.64.  Invocation command line was
  $ ./configure --prefix=/usr
## Platform. ##
hostname = sbRIO-9627-kontor
uname -m = armv7l
uname -r = 3.14.46-rt46-ni-3.5.0f0
uname -s = Linux
uname -v = #1 SMP PREEMPT RT Tue Jan 19 21:49:05 CST 2016
/usr/bin/uname -p = unknown
/bin/uname -X     = unknown
/bin/arch              = unknown
/usr/bin/arch -k       = unknown
/usr/convex/getsysinfo = unknown
/usr/bin/hostinfo      = unknown
/bin/machine           = unknown
/usr/bin/oslevel       = unknown
/bin/universe          = unknown
PATH: /usr/local/bin
PATH: /usr/bin
PATH: /bin
PATH: /usr/local/sbin
PATH: /usr/sbin
PATH: /sbin
PATH: /usr/local/natinst/bin
## Core tests. ##
configure:2344: checking for a BSD-compatible install
configure:2412: result: ./install-sh -c
configure:2423: checking whether build environment is sane
configure:2473: result: yes
configure:2614: checking for a thread-safe mkdir -p
configure:2653: result: ./install-sh -c -d
configure:2666: checking for gawk
configure:2682: found /usr/bin/gawk
configure:2693: result: gawk
configure:2704: checking whether make sets $(MAKE)
configure:2726: result: yes
configure:2815: checking whether make sets $(MAKE)
configure:2837: result: yes
configure:2896: checking for gcc
configure:2912: found /usr/bin/gcc
configure:2923: result: gcc
configure:3152: checking for C compiler version
configure:3161: gcc --version >&5
gcc (GCC) 4.8.2
Copyright (C) 2013 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.  There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
configure:3172: $? = 0
configure:3161: gcc -v >&5
Using built-in specs.
COLLECT_GCC=gcc
COLLECT_LTO_WRAPPER=/usr/lib/gcc/gcc/arm-nilrt-linux-gnueabi/4.8.2/lto-wrapper
Target: arm-nilrt-linux-gnueabi
Configured with: /builds/perforce/ThirdPartyExports/NIOpenEmbedded/trunk/3.5/objects/targettools/linuxU/armv7-a/gcc-4.7-oe/release/build/tmp-glibc/work-shared/gcc-4.8.2-r0/gcc-4.8.2/configure --build=x86_64-linux --host=arm-nilrt-linux-gnueabi --target=arm-nilrt-linux-gnueabi --prefix=/usr --exec_prefix=/usr --bindir=/usr/bin --sbindir=/usr/sbin --libexecdir=/usr/lib/gcc --datadir=/usr/share --sysconfdir=/etc --sharedstatedir=/com --localstatedir=/var --libdir=/usr/lib --includedir=/usr/include --oldincludedir=/usr/include --infodir=/usr/share/info --mandir=/usr/share/man --disable-silent-rules --disable-dependency-tracking --with-libtool-sysroot=/builds/perforce/ThirdPartyExports/NIOpenEmbedded/trunk/3.5/objects/targettools/linuxU/armv7-a/gcc-4.7-oe/release/build/tmp-glibc/sysroots/xilinx-zynq --with-gnu-ld --enable-shared --enable-languages=c,c++ --enable-threads=posix --enable-multilib --enable-c99 --enable-long-long --enable-symvers=gnu --enable-libstdcxx-pch --program-prefix=arm-nilrt-linux-gnueabi- --without-local-prefix --enable-target-optspace --enable-lto --enable-libssp --disable-bootstrap --disable-libmudflap --with-system-zlib --with-linker-hash-style=gnu --enable-linker-build-id --with-ppl=no --with-cloog=no --enable-checking=release --enable-cheaders=c_global --with-sysroot=/ --with-build-sysroot=/builds/perforce/ThirdPartyExports/NIOpenEmbedded/trunk/3.5/objects/targettools/linuxU/armv7-a/gcc-4.7-oe/release/build/tmp-glibc/sysroots/xilinx-zynq --with-native-system-header-dir=/builds/perforce/ThirdPartyExports/NIOpenEmbedded/trunk/3.5/objects/targettools/linuxU/armv7-a/gcc-4.7-oe/release/build/tmp-glibc/sysroots/xilinx-zynq/usr/include --with-gxx-include-dir=/usr/include/c++/4.8.2 --enable-nls --with-arch=armv7-a --with-arch=armv7-a --with-float=softfp --with-fpu=vfpv3 --with-tune=cortex-a9
Thread model: posix
gcc version 4.8.2 (GCC)
configure:3161: gcc -V >&5
gcc: error: unrecognized command line option '-V'
gcc: fatal error: no input files
compilation terminated.
configure:3172: $? = 1
configure:3161: gcc -qversion >&5
gcc: error: unrecognized command line option '-qversion'
configure:3194: checking for C compiler default output file name
configure:3216: gcc    conftest.c  >&5
/usr/lib/gcc/arm-nilrt-linux-gnueabi/4.8.2/../../../../arm-nilrt-linux-gnueabi/bin/ld: cannot find crtbegin.o: No such file or directory
/usr/lib/gcc/arm-nilrt-linux-gnueabi/4.8.2/../../../../arm-nilrt-linux-gnueabi/bin/ld: cannot find -lgcc
collect2: error: ld returned 1 exit status
configure:3220: $? = 1
configure:3257: result:
configure: failed program was:
| /* confdefs.h */
| #define PACKAGE_NAME "inotify-tools"
| #define PACKAGE_TARNAME "inotify-tools"
| #define PACKAGE_VERSION "3.14"
| #define PACKAGE_STRING "inotify-tools 3.14"
| #define PACKAGE_BUGREPORT "radu.voicilas@gmail.com"
| #define PACKAGE_URL ""
| #define PACKAGE "inotify-tools"
| #define VERSION "3.14"
| #define _GNU_SOURCE /**/
| /* end confdefs.h.  */
| #include <stdio.h>
| int
| main ()
| FILE *f = fopen ("conftest.out", "w");
|  return ferror (f) || fclose (f) != 0;
|   return 0;
configure:3263: error: in `/usr/src/inotify-tools/inotify-tools-3.14':
configure:3267: error: C compiler cannot create executables
## Cache variables. ##
ac_cv_env_CC_set=
ac_cv_env_CC_value=
ac_cv_env_CFLAGS_set=
ac_cv_env_CFLAGS_value=
ac_cv_env_CPPFLAGS_set=
ac_cv_env_CPPFLAGS_value=
ac_cv_env_CPP_set=
ac_cv_env_CPP_value=
ac_cv_env_LDFLAGS_set=
ac_cv_env_LDFLAGS_value=
ac_cv_env_LIBS_set=
ac_cv_env_LIBS_value=
ac_cv_env_build_alias_set=
ac_cv_env_build_alias_value=
ac_cv_env_host_alias_set=
ac_cv_env_host_alias_value=
ac_cv_env_target_alias_set=
ac_cv_env_target_alias_value=
ac_cv_prog_AWK=gawk
ac_cv_prog_ac_ct_CC=gcc
ac_cv_prog_make_make_set=yes
## Output variables. ##
ACLOCAL='${SHELL} /usr/src/inotify-tools/inotify-tools-3.14/missing --run aclocal-1.11'
AMDEPBACKSLASH=''
AMDEP_FALSE=''
AMDEP_TRUE=''
AMTAR='${SHELL} /usr/src/inotify-tools/inotify-tools-3.14/missing --run tar'
AR=''
AUTOCONF='${SHELL} /usr/src/inotify-tools/inotify-tools-3.14/missing --run autoconf'
AUTOHEADER='${SHELL} /usr/src/inotify-tools/inotify-tools-3.14/missing --run autoheader'
AUTOMAKE='${SHELL} /usr/src/inotify-tools/inotify-tools-3.14/missing --run automake-1.11'
AWK='gawk'
CC='gcc'
CCDEPMODE=''
CFLAGS=''
CPP=''
CPPFLAGS=''
CYGPATH_W='echo'
DEFS=''
DEPDIR=''
DOXYGEN=''
DOXYGEN_ENABLE_FALSE=''
DOXYGEN_ENABLE_TRUE=''
DSYMUTIL=''
DUMPBIN=''
ECHO_C=''
ECHO_N='-n'
ECHO_T=''
EGREP=''
EXEEXT=''
FGREP=''
GREP=''
INSTALL_DATA='${INSTALL} -m 644'
INSTALL_PROGRAM='${INSTALL}'
INSTALL_SCRIPT='${INSTALL}'
INSTALL_STRIP_PROGRAM='$(install_sh) -c -s'
LD=''
LDFLAGS=''
LIBOBJS=''
LIBS=''
LIBTOOL=''
LIPO=''
LN_S=''
LTLIBOBJS=''
MAKEINFO='${SHELL} /usr/src/inotify-tools/inotify-tools-3.14/missing --run makeinfo'
MKDIR_P='./install-sh -c -d'
NM=''
NMEDIT=''
OBJDUMP=''
OBJEXT=''
OTOOL64=''
OTOOL=''
PACKAGE='inotify-tools'
PACKAGE_BUGREPORT='radu.voicilas@gmail.com'
PACKAGE_NAME='inotify-tools'
PACKAGE_STRING='inotify-tools 3.14'
PACKAGE_TARNAME='inotify-tools'
PACKAGE_URL=''
PACKAGE_VERSION='3.14'
PATH_SEPARATOR=':'
RANLIB=''
SED=''
SET_MAKE=''
SHELL='/bin/sh'
STRIP=''
VERSION='3.14'
ac_ct_CC='gcc'
ac_ct_DUMPBIN=''
am__EXEEXT_FALSE=''
am__EXEEXT_TRUE=''
am__fastdepCC_FALSE=''
am__fastdepCC_TRUE=''
am__include=''
am__isrc=''
am__leading_dot='.'
am__quote=''
am__tar='${AMTAR} chof - "$$tardir"'
am__untar='${AMTAR} xf -'
bindir='${exec_prefix}/bin'
build=''
build_alias=''
build_cpu=''
build_os=''
build_vendor=''
datadir='${datarootdir}'
datarootdir='${prefix}/share'
docdir='${datarootdir}/doc/${PACKAGE_TARNAME}'
dvidir='${docdir}'
exec_prefix='NONE'
host=''
host_alias=''
host_cpu=''
host_os=''
host_vendor=''
htmldir='${docdir}'
includedir='${prefix}/include'
infodir='${datarootdir}/info'
install_sh='${SHELL} /usr/src/inotify-tools/inotify-tools-3.14/install-sh'
libdir='${exec_prefix}/lib'
libexecdir='${exec_prefix}/libexec'
localedir='${datarootdir}/locale'
localstatedir='${prefix}/var'
lt_ECHO='echo'
mandir='${datarootdir}/man'
mkdir_p='$(top_builddir)/./install-sh -c -d'
oldincludedir='/usr/include'
pdfdir='${docdir}'
prefix='/usr'
program_transform_name='s,x,x,'
psdir='${docdir}'
sbindir='${exec_prefix}/sbin'
sharedstatedir='${prefix}/com'
sysconfdir='${prefix}/etc'
target_alias=''
## confdefs.h. ##
/* confdefs.h */
configure: exit 77
I also tried Getting Started C/C++ Dev Eclipse Edition - but is stuck with:
sh -c /C/Users/USER/eclipse-workspace/inotify-tools/autogen.sh Cannot run program "sh": Launching failed Error: Program "sh" not found in PATH
Now, I wrote this so far, and then found these two:
which basically says
opkg install packagegroup-core-buildessential
and compiling works!
Only have to clean up the sbRIO-9627, which leads me to ask, how may I use Eclipse to compile?
What changes is necessary to overcome the error posted above?
In simple terms please
EDIT: Attached tarball with compiled binaries.
Also included our script that requires inotifywait:
#!/usr/bin/env bash
# corfilnam - Correct File Name
WANTED="$1"
# https://askubuntu.com/questions/385333/how-do-i-get-the-filename-from-inotifywait-events
inotifywait -m -q -e close --format '%f' "$2" | while read FILE
do
  # https://stackoverflow.com/questions/1728683/case-insensitive-comparison-of-strings-in-shell-script
  if [[ "$FILE" != "$WANTED" ]] && [[ "${FILE,,}" = "${WANTED,,}" ]]; then
    FULLPATH="$2/$FILE"
    if [ -f "$FULLPATH" ]; then
      echo "$(date) mv $FILE $WANTED"
      TARGET="$2/$WANTED"
      mv "$FULLPATH" "$TARGET"
      [ ! -z "$3" ] && chmod "$3" "$TARGET"
      [ ! -z "$4" ] && chown "$4" "$TARGET"
    fi
  fi
done
corfilnam.sh <wanted filename> <path> <chmod MODE> <chown [OWNER][:[GROUP]]>
./corfilnam.sh config.ini "/home/lvuser/natinst/Config" g+w lvuser:ni
06-20-2018 03:14 PM
I'm a little unclear on what you're trying to do. If you are able to compile on the target, why do you need to build inotify-tools using Eclipse?
06-21-2018 04:55 AM
My apologies for not making this explicitly clear.
I would like to compile with Eclipse to:
06-21-2018 04:32 PM
Those are all great reasons! I saw you mentioned the Getting Started guide above. Were you able to successfully build and deploy the Hello World example to your target? What step along the document did you get stuck?
06-22-2018 01:51 AM - edited 06-22-2018 07:19 AM
Sorry.
Yet another key detail I forgot to mention. Yes, I was able to successfully build and deploy the Hello World example to target. Meaning I did not got stuck at any step along the document.
Basically I think my question boils down to: Given that I have successfully completed the Hello World example, what changes and tweaks do I need to do in order to cross compile other software (than Hello World example) with Eclipse, in this case inotify-tools?
Hoping that an answer will help me (and other readers) learn how to build and deploy just about any software on sbRIO-9627 (and other targets).
I guess it has a lot to do with understanding the files:
Makefile.am autogen.sh configure.ac
and what the information in there means, and how that is transferred to Eclipse.
 metux
			metux
			07-19-2018 09:47 AM
@bhpaI guess it has a lot to do with understanding the files:
Makefile.am autogen.sh configure.acand what the information in there means, and how that is transferred to Eclipse.
That's one part of the story. These files are inputs for autotools (autoconf, automake, ...).
Looks like you're trying it under Windoze. I doubt that would really work.
Take a Linux box, set up the cross proper toolchain for your target and run crosscompiling / packaging through the bitbake machiney. Throw away the eclipse cruft - it doesn't help here.
(yes, you'll have to make yourself confident w/ crosscompiling and linux embedded development)
 ElectricEwok21
			ElectricEwok21
			01-13-2023 01:52 PM
Do you happen to have the .so files for your binaries? I am trying to use the same package on a 9627, but it seems to need the .so files for the binaries.
Thanks!
