02-09-2024 12:00 PM - edited 02-12-2024 04:19 PM
I've created a custom environment variable for the lvuser (i.e. MYPATH=/tmp/mydir). Now I want my LabVIEW application to read this environment variable, but when I use the System Exec.vi to call "echo $MYPATH", it returns blank. If I ssh into the RT, su to lvuser, and type the same thing, I get what I expect. What is the issue with doing this from the System Exec.vi in LabVIEW?
UPDATE 2/12/2024:
I created a VirtualBox with NI Linux RT (https://www.youtube.com/watch?v=s15gM5b635M) to continue testing this issue while the PXI is unavailable, and I am able to see the environment variable in the virtual machine just fine. So, I will have to continue investigating why I cannot get the same behavior from the embedded PXIe-8880 controller.
02-11-2024 05:48 AM
I don't have access to an LV RT instance to verify it for myself... Is there a chance that the shell in which your environment variable was declared is not the same one used by LV's System Exec call?
02-11-2024 09:56 AM
As someone who does a fair amount on Linux ( not RT just general Linux) this is most likely the problem. That or it is running as a different user.
02-11-2024 09:59 AM
Actually right after I hit send I seem to recall - don’t try progams run as lvuser or something. When you ssh are you logging in as lvuser - if so then that may be your problem.
intsead of env variables you could try storing it in a file - although you have be careful about permissions and iirc lvrt programs run in some kind of chroot? So you’ll have to make sure your lvrt program can find it.
02-12-2024 03:12 PM - edited 02-12-2024 03:18 PM
Thank you for the reply Taggart. I have been logging in as admin, then su lvuser to ensure the environment variable is set for lvuser.
Also, yes, the LV program runs as lvuser. I can use the System Exec.vi to run, "whoami" and it returns "lvuser".
Interestingly, running "env" through System Exec.vi yields a very small subset of the lvuser's environment variables. Basically, just PWD which has the value of the directory in which the LV program is stored, and SHLVL which equals 1. Perhaps this is why the environment variable is not accessible because the program is running in a lower level shell where the profile has not been updated?
Unfortunately, it seems like I will have to store the variable in a file.
02-13-2024 12:43 AM
Does it not even include SHELL, to indicate what shell is being used?
Perhaps you could try one more thing before resorting to a file approach - set the value at a system level in the /etc/ folder. There are multiple options, the following two links can give you a gist:
NOTE: You may wish to use the man pages of the actual environment, rather than the generic one above.
11-12-2025 02:54 PM
I am having the same issue. We have a CycloneDDS library that we have cross compiled for LabVIEW Linux and while we have it working there are some parameters that are set in a XML config file and this has to be set in an environmental variable
i have added , for example, the line in /etc/environment
CYCLONEDDS_URI="file:///home/lvuser/cyclonedds.xml"
but it doesn't seem to set the variable for the labview executable. You can verify when you run "env" command from systemexec. So fundamentally the same problem discussed here.
Anyone have any ideas?
11-19-2025 08:51 AM
Unfortunately I was not able to find an alternative and ended up putting the information in a file that LabVIEW reads in during initialization.
