 dntt3stm3
			dntt3stm3
			02-23-2024 06:24 AM
Have you tested your target or made any more advances towards this issue? I am in desperate need of a solution that hopefully works with 2024 because that's the only license I have. Thanks very much for your work so far!
02-23-2024 06:37 AM - edited 02-23-2024 06:38 AM
 rolfk
			rolfk
			02-23-2024 07:16 AM
If you have a valid commercial subscription you are actually entitled to download and activate also older versions.
 dntt3stm3
			dntt3stm3
			02-23-2024 07:17 AM - edited 02-23-2024 07:20 AM
Thanks for your quick response. I tried your method on 2023 and I'm at slightly below 50% available disk space on the target. Any suggestions on additional packages that won't keep me from being able to use MAX to configure the I.P. address and hostname?
 yamihere
			yamihere
			02-23-2024 07:39 AM - edited 02-23-2024 02:59 PM
have there been any updates to this procedure for 2021-2024?
I have removed the following pkgs and can communicate with my sbRIO via SSH but I cannot connect to it via the LabVIEW Project:
opkg remove ni-sysmgmt-salt-minion-support
opkg remove salt-minion
opkg remove salt-common
opkg remove ni-sysmgmt-sysapi-expert
opkg remove ni-arch-gen
opkg remove *python*
opkg remove gcc gcc-dev gcc-symlinks cpp kernel-dev kernel-devsrc libgcc-s-dev shared-mime-info binutils binutils-dev *ncurses* libfmi-dev libbfd bison-dev bison flex-dev flex-libf1 flex libstdc++-dev *perl* libmpc3 libmpfr4 --force-remove --nodeps
Notice that I did not remove unused packages. Also, can we use this procedure, or a modified version of it, and still be able to configure via MAX and or LabVIEW Project? I have tried this on a system that has 2024 and now have 70% free space on the sbRIO 9607.
 Jaleel
			Jaleel
			03-21-2024 03:23 AM
Remoal of "Driver install dependencies:" via command you mentioned on sbRIO-9651 causing FPGA target undetected. Which makes the entire system to format and reinstall the software.( FPGA initializing throws error -63192)
 yamihere
			yamihere
			03-21-2024 08:14 AM
@Jaleel, you may need to reconfigure your open FPGA refence. Please show all your settings and are you using a type def control?
If that doesn't work,
Have you tried it without using those commands? Also, how do you know it was those commands? (i.e. did you do any debugging to find root cause, if so, please list here.) If it was definitely those commands, AND you can't get the space you need without them (Did you check the %unused after each command?) try only deleting them one at a time. If possible, do some research and find out exactly what each one does to help determine root cause and the necessity of each one. Also, please expand the Software list on My System and on the Target to show us the versions of each module installed. Different Versions of LabVIEW and LV RT have different amounts of bloat.
Good Luck!
06-11-2024 06:19 AM
Will 2024Q3 have any improvements for this issue? Removal of the unused build dependencies e.g.?
(A thing that might require some space though is the need for a web GUI we can actually use for anything; like configuring the network interfaces and the clock without needing any NI software e.g...).
 Dan1345
			Dan1345
			10-01-2024 07:34 AM
We are currently trying to decide if we can move up to LabVIEW 2024 and I feel quite disappointed that Emerson /NI have not provided any sort of update on this, is it being worked on is there a plan to fix this in the next release.
05-13-2025 05:48 AM
This issue is still there in the 2025 Q2 image...Apart from causing trouble on sbRIO-9607 (which has been given extended life, which is good as it is one of few really low power alternatives...) I have the same issue on cRIO-9063.
The only official page about this is about the 2021 image, but the solution listed for that does not work in 2025. With Python taking up so much space it should not be installed by default, and should definitely be listed as a separate option in the package list.
