NI LabVIEW,CVI,数据采集等产品讨论区
VI Package Manager Install Xilinx Vivado
请问在Package Manager中如何安装Xilinx Vivado编译器,用于在本地编译labview fpga程序?
我找不到对应的package。
谢谢。
Message 1 of 11
(5,525 Views)
Depending on your LabVIEW version, you should either use the NI Package Manager, or just directly download the FPGA Module.
You won't find it in the VI Package manager.
Here's a possible link to get you started: https://www.ni.com/en-gb/support/documentation/compatibility/19/compatibility-between-xilinx-compila...
This allows you to select your LabVIEW version and hardware, then it will tell you which link to use for the FPGA module.
The online installers are just ~5MB, and include the option for you to install the Vivado or ISE compilers as desired.
Edit: This link might also be of interest, but it isn't a download link: https://forums.ni.com/t5/LabVIEW/Vivado-2017-2-Compilation-Tools-Direct-Download/td-p/4016094
GCentral
Message 2 of 11
(5,498 Views)
在NI Package Manager首页搜索关键字即可找到:
Message 3 of 11
(5,470 Views)
谢谢! 我在NI Package Manager确实找到了,安装时失败 “服务器过早关闭了连接”如附件failed所示。同时我在设置->源里面看到Vivado的地址为:
https://download.ni.com/support/nipkg/products/ni-v/ni-vivado-2017.2-cg/19.0/release
然后我手动进入这个地址,在support目录下,没有nipkg这个文件夹,如附件source所示。这是不是我安装失败的原因?
Message 4 of 11
(5,454 Views)
Thank you cbutcher!
I did found the compilation tool in NI Package Manager and tried to install it, but always got the message "
transfer closed with 1029755 bytes remaining to read".
The package source as stated is on server:
But I can not find the nipkg folder under the support folder.
Is this the reason I got the faild message?
Thank you!
Message 5 of 11
(5,450 Views)
Hi simonbatter,
I'm glad you found the download in NIPM, but I'm sorry that I don't know the possible cause of a failed download.
I expect that this directory is probably not available for public browsing. I tried looking on the NI FTP website but didn't see anything promising - you could try if you wanted but I don't think you will find the Xilinx compilers there.
Do you have the FPGA module installed? You might be able to re-run the installation and select the compiler additionally (this will not require time for the reinstallation of FPGA module - it will see you already have it installed - or at least, it does for other components...).
Perhaps pdengrd can give advice about the NIPM failed download?
GCentral
Message 6 of 11
(5,434 Views)
Accepted by simonbatter
我也不了解这个错误是什么原因导致的~是不是因为你网络有问题?我这边安装是正常的:
Message 7 of 11
(5,426 Views)
我这边可以更新其他package,但都无法成功更新,可能确实是网络问题 。我试着重新用ni fpga自安装程序装一次。
不管怎么样,谢谢你的支持!
Message 8 of 11
(5,414 Views)
I installed my fpga module from a standalone *.iso file, not from the NI Package Manager, because it always faild.
May be it is because my unstable network access.
I will try it again.
Thank you cbutcher.
Message 9 of 11
(5,411 Views)
确实是我的网络问题,我被政府墙了。我找了个梯子就可以正常安装了。。。。
谢谢你的提醒。
Message 10 of 11
(5,401 Views)
