01-25-2007 01:24 PM
01-26-2007 06:26 PM
I don't know if this has anything to do with your problem, but I did discover an error (I think). On your Pic you have a Bus3 going to RA0 and on the "Sleep" Switch you have it labeled as Bus2. I believe these have to be named the same in order to make the connection, otherwise the are going to two different busses. Try renaming them and see if this works for you.
If it has something to do with the PIC, then Nestor would probably know more about that than I. I thought I would just point out this connection error just in case that was the problem.
01-27-2007 05:00 AM
03-19-2009 02:02 AM
Send me across the schematic picture. I can have a look.
- J
