Multisim and Ultiboard
Using template file as an input to simulate multisim circuit
I am building  circuit on multisim that would detect eye signals as an input to that circuit. Does anyone know how to use a template file as an input to a circuit?
The input templates are taken from this source
https://physionet.org/mimic2/Signals_Class/record_indeces/pages/EOG_recind.shtml
Thank you.
(2,494 Views)
Hi reytz21
I did not find a direct way to use .rec files as inputs in Multisim. There are other options to generate input signals like the function and signal generators. I also found the Piecewise Linear Source that could help you to generate control shape waveforms with pairs of time and voltage/current values.
astromaut
(2,463 Views)
