Multisim and Ultiboard
Implementing Solid State Relays
Hi, I'm new to Multisim and have only used LtSpice in the past. I just started a circuit and am having difficulty figuring out how to use a solid state relay.
I know the component I want but it's not in the master library. I considered using an equivalent component and changing the values but the component guide is extremely sparse, it doesn't describe how to adjust any of the component properties when it comes to relays.
Also none of the relays seem to describe SSRs, they are mostly magnetic relays.
Do I have to create my own component then? Before going down that route I would like to make sure it's not necessary.
I'm at a loss as to why things aren't clear, what is one supposed to do about solid state relays in multisim?
Message 1 of 1
(2,452 Views)
