Multisim and Ultiboard
RLC, Single frequency AC analysis results do not match hand caculated results.
On a simple RLC simulation single frequency AC analysis, the resultant magnitudes are off by factor of 10. Phase angle values are all correct and match the calculated values. On a different example worked out in a text book, same results.What am I doing wrong?   Also, how do you change the AC source from RMS to peak or vise versa? Thanks.
Message 1 of 14
(8,762 Views)
HI,
Can you post your circuit and what your expected result.
There are two AC sources, one has a default of 120 Vrms and the other is 1Vpk.  In the Select Component dialog under the Sources group, Power Sources family have the 120Vrms and in the Signal Voltage Sources you will find the 1Vp source.  When you are running an AC or Single frequency analysis, double click on the source you placed on the schematic and you will see a field AC analysis magnitude, this magnitude is use in the AC and single frequency analysis.  The default for both sources is 1V, so if you Vin is other than 1V, you need to chagne this field.
Tien P.
Message 2 of 14
(8,754 Views)
First of all thanks very much for your reply.
Here are the requested info:
Circuit diagram
Message 3 of 14
(8,749 Views)
Multisim output
Message 4 of 14
(8,748 Views)
My hand calculated results:
For this example, I get:
Z = 400 – j300
Z, mag = 500, phase = -36.86
I, mag = 0.04, phase = 36.86
VR, mag = 16 , phase = 36.86
VL, mag = 52, phase = 126.86
VC, mag = 64, phase = -53.14
The Multisim magnitude values are all off by factor of 20. Phase values are all correct.
These hand calculated values are correct sin sqrt( R ^ 2 + (VC – VL ) ^ 2) = 20 which is the source voltage.
Message 5 of 14
(8,747 Views)
Can you post the Multisim file, I like to see how you set everything up.
Notes for Branch AE:
Please reply to This Post within 24 hours
The US AE is expected to reply to all of your posts within 24 hours. Having this expectation will keep the escalation moving quickly and toward a fast resolution.
You can also use other communication channels: Phone, Skype, etc. to discuss the issue with the US AE. This can help with troubleshooting and quick diagnosis of the issue.
Click here to provide kudos for a post on this page
Message 6 of 14
(8,745 Views)
Just in case the circuit diagram is not very clear.
All components are in series:
AC source: 20 Vp at 795.77 hz or 5000 rad/sec, phase = 0
R = 400 Ohm
L = 260 mH
C = 125 nF
Message 7 of 14
(8,744 Views)
I am new here and not sure how to attach the file as I do not see an attach link for attaching a file.
Message 8 of 14
(8,742 Views)
After you click the Reply button, you should see a Browse button click on it navigate to the location where you saved the file.  Some file extension is not allowed to be attached on NI forum; if the file you want to attach won't load you have to zip it.
Message 9 of 14
(8,736 Views)
