 bangkaew
			bangkaew
			07-26-2010 07:18 AM
 tested multisim for Parallel RLC Circuit with voltage source as in
http://www.electronics-tutorials.ws/accircuits/parallel-circuit.html
But the current flows through the inductance L has DC component as in the picture attached (the red sine wave). Is it a bug ?, please tell me how to correct it.
07-26-2010 07:30 AM
It may be difficult to use Multisim to illustrate and explain the phase relation of RLC  circuit in parallel in the same way as what many people  usually do without no offset as in ,
Anyway, Multisim is perfect for RLC circuit in series as in the photo attached.
What is wrong ? should it be corrected to make it consistent with what most people think. ?.
07-27-2010 10:46 AM
In Multisim select menu Options>>Global Preferences>>Simulation, under "Positive phase shift direction" change the phase shift setting and then press Apply and OK. Double click on your AC source on the schematic and verify the phase shift is correct and simulate your circuit again, this will likely fix the simulation error.
07-27-2010 10:46 AM - edited 07-27-2010 10:47 AM
a
07-28-2010 08:23 AM
Thanks, Tiens
I tried it ,but to no effect.
The problem is not the phase shift , but the magnitude which contain offset or DC component in the current flowing through ideal inductance.
I attached the file for your testing.
07-30-2010 03:52 PM
Hi there,
As strange as this may sound, this is not a bug. OK, this sounds really funny, but I am totally serious, and I am going to explain why:
OK. Now look at what happened. During the whole cycle, the current was positive only! The current increased during the first half of the cycle and returned to 0 during the second half. This is because of the fluke of initial conditions! In fact, a good circuit simulator will maintain the DC offset for a long duration. The DC offset may drift because of rounding errors and the like.
This will never be observed in real life as real inductors have winding resistance and other problems.
OK, so, if you would like to see no DC offset, do the following:
It took me a while to figure this one out. Hope that helps!
08-01-2010 04:57 PM
Thanks, Yi
I have tried what you said, but to no effect.(nothing changes, the phasor diagram tool shows the same offset)
and I don't think this is a good solution.
When I changed from voltage source to current source, the offset disappears.
Is it possible that current and voltage phase relation of inductor is derived from current as input and voltage drop as output, when you reverse the cause and effect , the result may not be the same.
So, when pure inductor is found directly connected to a voltage source, Multisim should perform some procedure to maintain a steady state value with no offset. I think.
08-03-2010 04:04 PM
I'm attaching your original file that has been modified to have no DC offset in the inductor.
I don't have your phasor VI, so I substituted an ordinary 4 channel oscilloscope. You can replace it with a phasor VI again and it should work fine.
08-07-2010 08:06 AM
Thanks, Yyao
Your file can not be download or opened.
I have tried what you said by connecting to 4 channel oscilloscope as attached , but to no effect.(nothing changes, the signal shows the same offset as the green sine wave)
 digitalguy
			digitalguy
			08-07-2010 10:52 AM
FYI, the file opens and works perfectly for me. I have Multisim 11.
Howard
