08-11-2010 09:58 AM
Try this:
08-11-2010 09:44 PM
Thanks Yyao, it works now.
Just wonder how many people know that
.... current and voltage phase relation of inductor is derived from current as input and voltage drop as output, when you reverse the cause and effect , the result may not be the same.
Most textbooks and websites are unaware of this offset problem for pure inductor,
09-29-2010 06:54 PM
Y
I had somewhat similar problems for slightly different circuit parameters. To quote your peer Tien
"The model of an inductor is essentially a voltage source and when you have
two voltage sources in parallel you create an conditions known as "voltage
loop", ..... This issue is not unique to Multisim and it is an issue with any SPICE simulator."
Switching to a current source like was done above may have been a solution.
Lastly, in the past someone at NI suggested the offset might be due to integration method.
09-30-2010 03:03 PM
Hi Bob,
Thanks for sharing this with us!
10-01-2010 02:22 AM
Thank you for your interests in the problem, Below is my opinion.
In real world, the pure inductor does not exist, its inductance L is always in series with its small resistance R, so there is a time constant = L/R to consider before it reaches steady state. For the case of pure inductor, R=0 that makes Time Constant becomes infinite, and the offset left forever.
My suggestion is that if you are interested in only the result for the steady state , other method should be used instead of numerical integration.
08-09-2011 07:59 PM
thanks
