Multisim and Ultiboard
Need help with osilator circuit
I need help osilator circuit doesnt work
(2,812 Views)
Have you checked the error message in detailed help? It seems to explain the source of the error and it also gives you some possible solutions. I recommend you to take a look at this (see picture attached).
Pamela Gómez
Applications Engineering
www.ni.com/support
(2,785 Views)
Thank you for your help  but Mixed mode Simulation settings have already set the ideal pin models when I changed "Use real pin models" I get singnal but it is fluctuating very rapid (frequency and voltage.)
(2,778 Views)
disconnect the output of your gate from the power supply.
(2,750 Views)
