11-04-2018 09:51 AM
I want to export a gerber file RS-274X for a small milling machine and I would like to know how do I remove these "artifacts".
Thank You
11-07-2018 03:43 PM
Gerber RS-274X
Fiducial marks, which appear in Gerber files, are set in the Global Options dialog box.
11-07-2018 08:42 PM
Under the Options menu in Ultiboard, select Global Options to open its dialog box.
Select the PCB Design tab.
Uncheck the Show global fiducial marks item to hide these marks.
However, fiducial marks are only used as a reference in Ultiboard. These marks shouldn't affect the manufacture of your PCB.
You can find a little more information about the PCB Design Tab and the fiducial marks at this link.
Alejandro Balma
