Multisim and Ultiboard
MTP10N05E/MC cannot get this MOSFET to turn on
Tried several things to get this mosfet to work(turn on). Tried to find a datasheet on it. Could not even find that. Need some direction with this particular device.
(3,506 Views)
When you look in the data tables there is nothing there..
(3,490 Views)
There you go about the datasheet.
http://www.datasheets360.com/pdf/172772505368078202
The model you are trying to simulate is not working. Just use another one, e.g. MTP15N05E.
(3,430 Views)
There is not another with this label....Not sure when you go into the pin menu why none of the pertinent information is not entered????
(3,411 Views)
The "pertinent" information was not available for the orignal FET you were trying to use. The one I suggested you has.
(3,404 Views)
