08-20-2017 09:02 AM
Tried several things to get this mosfet to work(turn on). Tried to find a datasheet on it. Could not even find that. Need some direction with this particular device.
08-20-2017 09:31 AM
When you look in the data tables there is nothing there..
08-21-2017 02:30 AM - edited 08-21-2017 02:41 AM
There you go about the datasheet.
http://www.datasheets360.com/pdf/172772505368078202
The model you are trying to simulate is not working. Just use another one, e.g. MTP15N05E.
08-21-2017 03:54 PM
There is not another with this label....Not sure when you go into the pin menu why none of the pertinent information is not entered????
08-22-2017 02:08 AM
The "pertinent" information was not available for the orignal FET you were trying to use. The one I suggested you has.
