Multisim and Ultiboard
Internal Program Error 1173
I am using Ultiboard 10.0.1. When starting the autorouter, I get the following message: Error during autorouter preprocessing. Source: Autorouter Internal Program Error 1173 What does it mean? Thanks, Gary
(4,668 Views)
Is this happening with a particular design file? What's your operating system?
Fernando D.
(4,637 Views)
I am usinh WinXP SP2. I *think* the problem may have been with the board outline. I had to "fiddle" with the outline in AutoCAD by joining all of the corners to make sure it was a closed shape before importing the DXF into the board outline layer. It seemed that only sometimes Ultiboard would complain the outline was not a closed shape. Sometimes it would offer to autoclose the outline and 10 mil would work. Sometimes even 100 mil would not work. Sometimes I just got the 1173 error. To make the short story long, I redrew the board outline one segment at a time and the error message went away. I'm not sure if I fix it, or something else I did made the error go away. Just what is error 1173? Thanks
(4,633 Views)
Accepted by GaryAtAMI
Thanks for the info. I did further research and it seems that this error could be a defect that was fixed in version 10.1. If you continue getting the error, could you please send us your design file for testing? Just send us an email to ewbsupport@ni.com.
Fernando D.
(4,591 Views)
Thanks Fernando! The next time the error pops up I'll let you know. NI SUPPORT IS GREAT! Gary
(4,581 Views)
