Multisim and Ultiboard
How to set the 'Configuration Bits' in the PIC16F84
I am using the PIC16F84 in a circuit and I'm programming the assembly for the PIC.  However I can't figure out how to set the configuration bits.  For example I want to select the LP Oscillator, turn the WDT off, turn the PUT on, and turn the CP off.  Normally if I was using the IDE from Microchip I would add the line:
_CONFIG H'3FF0'
However Multsim does not recognize this as a valid code.  In addition the P16F84.inc file contains the following definitions:
_CP_ON                       EQU     H'000F'
_CP_OFF                      EQU     H'3FFF'
_PWRTE_ON                 EQU     H'3FF7'
_PWRTE_OFF                   EQU     H'3FFF'
_WDT_ON                      EQU     H'3FFF'
_WDT_OFF                     EQU     H'3FFB'
_LP_OSC                      EQU     H'3FFC'
_XT_OSC                      EQU     H'3FFD'
_HS_OSC                      EQU     H'3FFE'
_RC_OSC                      EQU     H'3FFF'
What is the code though to select which options you want to use?
(4,879 Views)
Try this code:
_CONFIG _CP_OFF & _PWRITE_ON & _WDT_OFF & _LP_OSC
I tried this in the assembler and it didn't return any error messages when compiling. I found this in a PIC Book that I downloaded off the internet.
I hope it works for you. I am new to the MCU Module and learning about it so don't consider me an expert on it by a long shot.
Have A Nice Day
Kittmaster's Component Database
http://ni.kittmaster.com
Have a Nice Day
(4,866 Views)
