Multisim and Ultiboard
取消
顯示結果
搜尋替代
您的意思是:
DC output from the power supply is incorrect
Please help review attached simple power supply circuit and let me know why the measured DC voltage rails only +/-50V, but not 168V (by calculation)?  Any your comments will be appreciated!
Anadig
Anadig
0 積分
1 條訊息(共 4 條)
3,632 檢視
I just figured it out.  Problem solved!
Anadig
0 積分
2 條訊息(共 4 條)
3,631 檢視
I thought I have solved this problem by using virtual diode models for D1~D4.   However, when replacing the virtual diodes with 1N5407 (from ON Semi PSPICE model) or other diode models in the NI Standard library, the DC output always at 50V regardless of what input AC voltage is?  Please help review the attached circuit and advise it if you can.
Anadig
Anadig
0 積分
3 條訊息(共 4 條)
3,610 檢視
I think I resolved the problem again.  Thanks!
Anadig
0 積分
4 條訊息(共 4 條)
3,594 檢視
