10-08-2007 06:20 AM
10-08-2007 06:35 AM
10-08-2007 09:57 AM
O.K. Here goes the explaination and I hope It isn't confusing.
1 ) Your model will not work as is and it has to be edited for compatibility. The corrected model is below
Model NUHFARRY NPN
+IS = 1.840E-16
+XTI = 3.000E+00
+EG = 1.110E+00
+VAF = 7.200E+01
2) I am sure you are at least somewhat familiar with the component wizard. If not then your documentation should provide you with a great deal of knowledge on how to create components (better than I could explain). Anyway, I went into the component wizard and set this component up for simulation only. I selected a symbol from the master database to use. Then when I got to the place where you can paste a model into the window, I did that. While in that same dialog box, you have to make sure that you put in a model name in the very first box or otherwise it will not accept your model information. Change EMPTY to something else preferably NUHFARRY as is stated in the first line of the model file. You probably could use another name, but it is better to use the name in model file just to be sure.
I then created a simple switching circuit to test to see if it worked and it did without error.
One other thing, when it asks for pin>model mapping it will give that information at the bottom of the window. Just enter it as it states there. This maps the E B C to the model pins 1 2 3.
If this is to complicated for you at this time, I can post my circut with the created transistor and you can just save it to your database if you have that option in your version and if you have Version 10
I hope this helps
10-08-2007 10:16 AM
