Multisim and Ultiboard
Reply
Conveyor belt simulation in Multisim 14.1
Can anybody tell me how to create a working simulation desing with the Conveyor_belt in Multisim 14.1?
The educational sample comming with Multisim works perfectly.
However in any new design I create, the box on the conveyor belt won't move, no matter the state of any one of the pins Fwd and Rev.
When I put 5V on one of Fwd or Rev pin, I can clearly see the Wheel turning at high speed, no matter the value for maximum speed I put in the conveyor belt properties.
Are there some configuration values not pointed in Multisim Help that must be set to get a working simulation?
(319 Views)
Highlighted
Re: Conveyor belt simulation in Multisim 14.1
Hi Jack_22,
Is this the help document you took a look at? Are you creating a custom conveyor belt in your new design? Maybe this document can help shine a light to see how to set the conveyor logic and get the simulation working?
(284 Views)
Hi Chaka123,
Thanks for links, but I've already had a look at both of them.
The second document is the description of the educational sample comming with Multisim. This one works fine.
My problem is when I try to create a new design. If I place the CONVEYOR_BELT component from the Master Database in my new design, (or even if I copy and paste the one from the Multisim sample) there is nothing I can do to control the speed of this conveyor belt nor make the box move in any simulation.
I guess this situation has to do with some simulation parameter(s) not set correctly but I can't figure out which simulation parameter(s) should be set and what are acceptable values. Moreover, there is nothing regarding this issue in the help documents.
(274 Views)
Hello Jack_22,
Can you share an example Design in which you have the Conveyor_Belt setup and not working, to see if the error is reproduced and check what should be changed?
Regards.
(263 Views)
Hi jdel12,
Here is a simple example. As I stated in a previous post, this setup makes the motor spind at high speed when started with "G" or "D" (despite a specified maximum speed of 0.25 m/s) and the box doesn't move. The logic involving the TTL gates is totally correct and the resistors are simple pull down.
I am convinced that it has to do with some simulation parameter(s) not set correctly, however I can't figure out which one(s) and even less what their value(s) should be!
(225 Views)
I finally found that for the CONVEYOR_BELT to run properly in a new Multisim 14.1 Design, the parameters TMAX and TSTEP under "Interactive Simulation" of the menu "Simulate - Analyses and simulation", must be modified.
Default value for these parameters when creating a new Design is "Determine automatically". To change this value, check the box in front of the parameter name and enter the desired value.
I got good results with TMAX=0.1 s and TSTEP=0.1 s.
(197 Views)
