Multifunction DAQ
vi program for controlling bender element needed
Can you please send me a vi program to control bender elements (transmitter and receiver transducers)in a soil triaxial test? I am trying to generate and receive S wave signals simultaneusly and measure travel time. I would be appreciated if any body send me the vi program to control my bender elements (GDS Inc). Thanks.
(3,047 Views)
I googled this transducer and it looks like you need to have a data acquisition card to acquire/generate analog signals. Once you have the card, you should be able to create a VI to analyze the signals. However, the DAQ card is going to need to a driver and hopefully VIs to control it. If you're using a National Instruments DAQ card, you will need to install NI-DAQ. If you're using another vendor's card, they will need to provide you with VIs or a DLL that you can access from within LabVIEW.
Hope this helps.
Erin
(3,047 Views)
Hi Erin:
Thanks for your email. well I have ni card ( pci 6031) and am using lab view 6i. I wanted to know if you have the vi you were using for your bender elements?
I would be appreciated if you sent it to me.thanks.
(3,047 Views)
I've never used this particular transducer before. You can download the latest NI-DAQ driver here:
http://digital.ni.com/softlib.nsf/websearch/50F76C287F531AA786256E7500634BE3?opendocument&node=132060_US
This driver includes the DAQ VIs that you can use to control the 6031E. As far as a VI to work with your particular transducer, I suggest that you contact the vendor to determine the type of signal conditioning and control needed to communicate with this device.
http://www.gdsinstruments.com/group_SP/bender.htm
Once you know that information, you can develop a VI to acquire and generate the waveforms needed for this transducer. I also did a google search on bender elements and LabVIEW and found some research papers that might intere
st you:
http://www.google.com/search?sourceid=navclient&ie=UTF-8&oe=UTF-8&q=+bender+element+labview
Hope this helps you out some.
Erin
(3,047 Views)
