04-18-2009 06:15 PM
Dear Members,
I am using NI-PCI 6035E DAQ board with labview 8.2. Now I have one signal coming from one sensor from which I need to filter out one particular frequency component ( after acquiring the signal, I have to do the filtering in labview only) and then based on the filtered signal ( when the filterd signal crosses a threshold value with a positive slope) I need to generate an output voltage which will act as a trigger for image capturing by a ccd camera.
I found out from " find examples" two examples "cont gen voltage wfm-int clk-analog start.vi" and "cont Acq & graph voltage-Int clk.vi" . I tried to put them in one programme but i could not figure out how to include the filtering operation in that. So kindly suggest any way out for this problem
04-20-2009 10:48 AM
Hi
You can either use the lower level filter vis in LabVIEW or an Express Vi. The lower level functions can be found in the functions palette under Signal Processing>>Filters and the express vi is under Express>>Signal Analysis. Also there are examples in the NI Example finder that shows how to integrate them into a program.
Help>>Find Examples and search for Filter or filtering. Some examples to review are Filter and Express Filter.vi but there are many others you could reference for your application.
