retriggerable digital output strange behavior
I have created a digital edge retriggerable digital output (finite) task as the following: (in DAQmx C)
DAQmxCreateTask("",&_taskHandle);
DAQmxCreateDOChan(_taskHandle,"/Dev2/port0/line6","",DAQmx_Val_ChanPerLine);
DAQmxCfgSampClkTiming(_taskHandle,"/Dev2/Ctr0InternalOutput",_clockRate,DAQmx_Val_Rising,DAQmx_Val_FiniteSamps,static_cast<uInt64>(_sampleCount));
DAQmxCfgOutputBuffer(_taskHandle,static_cast<uInt32>(_sampleCount));
DAQmxCfgDigEdgeStartTrig(_taskHandle,"/Dev2/PFI4" ,DAQmx_Val_Rising);
DAQmxSetStartTrigRetriggerable(_taskHandle,true);
DAQmxWriteDigitalLines(_taskHandle,static_cast<int32>(_sampleCount),FALSE,-1,DAQmx_Val_GroupByChannel,_pDigital,NULL,NULL);
DAQmxStartTask(_taskHandle);
///// sample clock:
DAQmxCreateTask("", &_taskHandleCO);
DAQmxCreateCOPulseChanFreq(_taskHandleCO, "/Dev2/ctr0", "", DAQmx_Val_Hz, DAQmx_Val_Low, 0.0, _clockRate, 0.5);
DAQmxCfgImplicitTiming (_taskHandleCO, DAQmx_Val_ContSamps, _numSamples);
DAQmxStartTask(_taskHandleCO);
When I run the task without setting retriggerable, it output correct signal. However, if I run with retriggerable, it output almost exact 2 times faster than normal. For example, a pulse with width of 10 ms became 5 ms, and repeat itself again to be 2 pulse of 5 ms. It is repeatable no matter how many or how fast the triggers supplied.
My card is PCIe-6363. I don't know what causes this strange behavior, and hopefully someone can help on this.
Thank you.
(3,419 Views)
Have you check the example of DAQmx in C about a Retriggerable task?
Look for it at the attachments. In this example it comes how to do a retriggerable task with DAQmx C. Try implementing the Retriggerable function as they do in this example.
(3,370 Views)
Accepted by skuo1008
It goes away after reset configuration. Might be worthwhile for future notice.
(3,334 Views)
Hi!
Please mark your post as the solution so it can be used for future reference.
(3,290 Views)
