more than 8 DIO on SCB 68
we' ve got PXI 6254 M with a SCB 68.
The problem is that the SCB 68 only has the possibility to connect 8 DIO. So I can connect 16 DIOs with the 2 SCB 68 on the PXI 6254 M. But the PXI 6254 M has 48 DIO. How can I use them.
Thank you very much.
Greeting
Mark Junge
(5,048 Views)
Hello Mark,
The SCB-68 breaks out all 68 pins of the 68 pin connector of your NI 6254.  If you have one SCB-68 on each 68 pin connector, then you do have access to all the digital lines of your device, 24 digital lines on each SCB-68.  So, looking at the pinout of your device, you can see the digital line P0.0 is pin 52 and P1.0 is pin 11 of the SCB-68 on the first connector.  On the second connector, P0.30 is pin 1, etc.
-Alan A.
Message Edited by Alan [DE] on 02-07-2006 11:47 AM
(5,045 Views)
Hello Alan,
thank you very much for your answer. But how can I access this DIOs on the SCB 68?
Greetings
Mark
(5,022 Views)
Mark:
The screw terminal numbers have a one to one correspondence with the pin numbers of the 68 pin connectors on the DAQ card.
(5,015 Views)
