Multifunction DAQ
Run-time error 10444 what am I doing wrong?
My software stops running with error message 10444 - no more memory etc. Any ideas what I am doing or not doing to cause this problem?
(3,214 Views)
A little more information would probably help here:
What software are you using (LabVIEW, CVI, C++...) and what version?
What are you doing in your program?  Are you building unbounded arrays (In LabVIEW, this would be something like a build array in a loop) ?
What is your system like, i.e. RAM, etc.
Are you using any NI hardware?  If so, what?
-Alan A.
(3,200 Views)
Hi Alan,
Thanks for taking the time to reply. I'm using VB6 and E series DAQ cards. I was mistakenly doing a .config with every .start and eventually running out of memory. It's looks fixed now. Thanks again.
Peter M
(3,181 Views)
