‎09-17-2005 11:18 AM
‎09-19-2005 10:50 AM
Hello Hiren,
I plugged that error code into the Explain Error Utility in LabVIEW (Help >> Explain Error) and pulled up this information:
Error -200587 occurred at an unidentified location
Possible reason(s):
Requested operation could not be performed, because the specified digital lines are either reserved or the device is not present in NI-DAQmx. It is possible that these lines are reserved by another task, the device is being used through the Traditional NI-DAQ interface, or the device is being reset.
If you are using these lines with another task, wait for the task to complete. If you are using the device through the Traditional NI-DAQ interface, and you want to use it with NI-DAQmx, reset (initialize) the device using the Traditional NI-DAQ interface. If you are resetting the device, wait for the reset to finish.
‎09-19-2005 11:08 AM
