do you need a supply to input current with the ni daq 9265
Hello I just got the NI Daq 9265 for research in my lab. I am trying to input current and display it on an oscilloscope. I am getting nothing. I have done some research on the internet, so my question is do you need a power supply to input current with the ni daq 9265?
(6,234 Views)
Accepted by reggie2016
Read the data sheet.  Clearly in the first page is a sentence that reads "The NI 9265 requires a 9 V to 36 V external power supply."
GCentral
(6,231 Views)
Just needed someone else to tell me.
(6,229 Views)
reggie, whenever you need to know more about a specific piece of hardware, you check the datasheet. I know sometimes it's a bit daunting when you haven't worked with intruments like this before, but the datasheets always have the information you need. A lot of the time you also read something about it that you didn't even think to check, so knowing the part inside and out will save you time down the line. If you're spending $384 on a piece of hardware, it's worth reading the datasheet front to back.
Even looking up the pinout shows you that a voltage supply is required:
Cheers
--------,       Unofficial Forum Rules and Guidelines                                           ,--------
          '---   >The shortest distance between two nodes is a straight wire>   ---'
(6,216 Views)
I looked over it and saw it say you needed a power supply but I guess that seemed wierd to me since I was using the DAQ 9263 previously and you didn't need one then. So I thought the power supply was optional.
(6,211 Views)
This power supply is for the specific module. It needs some voltage source in order to output a varying current. You would not want this to be outputting a varying current from the cDAQ's power supply, as you would end up with a very noisy output.
Cheers
(6,204 Views)
