02-03-2016 10:36 AM
Hello I just got the NI Daq 9265 for research in my lab. I am trying to input current and display it on an oscilloscope. I am getting nothing. I have done some research on the internet, so my question is do you need a power supply to input current with the ni daq 9265?
02-03-2016 11:15 AM
Read the data sheet. Clearly in the first page is a sentence that reads "The NI 9265 requires a 9 V to 36 V external power supply."
02-03-2016 11:17 AM
Just needed someone else to tell me.
02-03-2016 12:12 PM - edited 02-03-2016 12:12 PM
reggie, whenever you need to know more about a specific piece of hardware, you check the datasheet. I know sometimes it's a bit daunting when you haven't worked with intruments like this before, but the datasheets always have the information you need. A lot of the time you also read something about it that you didn't even think to check, so knowing the part inside and out will save you time down the line. If you're spending $384 on a piece of hardware, it's worth reading the datasheet front to back.
Even looking up the pinout shows you that a voltage supply is required:
Cheers
--------, Unofficial Forum Rules and Guidelines ,--------
'--- >The shortest distance between two nodes is a straight wire> ---'
02-03-2016 12:16 PM
02-03-2016 12:29 PM
This power supply is for the specific module. It needs some voltage source in order to output a varying current. You would not want this to be outputting a varying current from the cDAQ's power supply, as you would end up with a very noisy output.
Cheers
