Multifunction DAQ
configuration of the NI PCI 6221
Can I configure the NI PCI 6221 to acquire data from different measurement types at the same time, or are do they acquire only one type of measurement with each configuration?
(3,561 Views)
Hello nak,
With NI-DAQmx, you certainly can have a task containing multiple measurement types.  In MAX, or using the DAQ Assistant, you can use the "+ Add Channels" button to add channels of any type.  Or, programmatically, in LabVIEW (or with the C API), you can use multiple DAQmx Create Channel VIs (or functions) to add channels of different types to one task.  See the image for examples of both.  Hope this helps!
-Alan A.
Message Edited by Alan [DE] on 01-26-2006 11:24 AM
(3,553 Views)
Hello Alan,
thanks a lot for your helpful suggestion. It works very well.
Nak
(3,543 Views)
No problem at all!  Best of luck with your app 🙂
-Alan A.
(3,539 Views)
