Thanks Tom for your suggestion to try NI-DAQ 8.0. I just saw it today. Yesterday,
I was able to isolate 3 PCI-6221-37 boards as defective because they all wouldn't work in another computer while
one other identical model card did work in that same computer. I called to arrange to return them to NI and learned
that for these 3, I needed NI-DAQ 8.0. The fourth one was okay
with NI-DAQ 7.5. Apparently, this was a known problem.
I wish NI would have simply notified me that my boards would
not work with the software sent with them and sent the NIDAQ 8.0 CD as soon as they knew rather than have me
waste a day of my engineering time trying to figure it all out. Booo NI.
One of the boards has worked for almost a day under NIDAQ 8.0. I was able to make some progress on the
system I am building. But then it stopped working. LabVIEW
(version 7.0 executable) programs would not open completely
or would open slowly. One that accessed the COM port only (no
data acquisition) did work. MAX opened very slowly or not at all
and when I click on
Devices and Interfaces, the hourglass is up for a long time and finally the + icon goes away indicating that MAX is not
aware of any devices being present. The Windows Device Manager says the board is present and working. Windows
Task Manager lists LabVIEW Runtime and MAX when only MAX is open and indicates that MAX is Not Responding.
I shut down the computer, removed the PCI-6221 board, booted it up again, and MAX is the same way. I uninstalled
MAX and NI-DAQ LabVIEW 7.0 support and then reinstalled them.
Now the MAX loading window is up for more than a minute and NIMAX.exe is listed in Task Manager's processes. After
the first minute, LabVIEW Runtime appears in the Task Manager's
Applications list. After a while longer, the MAX window finally
opens
and MAX is listed in the Applications. I click on the + icon by Devices and Interfaces in MAX and the hourglass appears
and Windows Task Manager says MAX is Not Responding. Eventually, the + icon and the hourglass go away and
the Task Manager lists LabVIEW Runtime and MAX as Running.
I shut the computer off for several minutes, started it up again, and MAX is still takes a long, long time to open.
I haven't put the PCI-6221 card back in because MAX still isn't working.
What do you suggest I do next?
Halden
