Multifunction DAQ
cannot trigger both DAQ and camera
I want to synchronize a camera and a pressure transducer. The pressure transducer is connected to a NI USB-6251.
I'm using a TTL signal to trigger (the trigger signal is coming from a Labjack). If I connect only the camera, I can trigger it without trouble. If I connect only the DAQ card, I can trigger without trouble. If I use a T-connector to both trigger the camera and the DAQ card, only the DAQ card is triggered.
Any idea of the source of the problem and how I can fix it? Thanks!
Charlotte
(3,461 Views)
Have you checked the "TTL"  signal after splitting? Are the levels still TTL?
André (CLA, CLED)
(3,460 Views)
I didn't check, but clearly it's affected by the presence of the camera or DAQ card. I'll check it right now, but if the TTL is modified, that means I have an impedance problem, right? How can I fix this?
Charlotte
(3,450 Views)
Accepted by Charlotte
Ok, so I checked my TTL signal and it was perturbed once splitted. I pulled out another TTL signal such that the camera and the DAQ card has each one its own TTL trigger: it's working nicely and now I can enjoy my weekend :))
(3,447 Views)
