03-25-2015 10:38 AM
I am using an FPGA I/O Property node to get the Serial Number and Module ID for each module in my cRIO-9081. The serial numbers match exactly what I thought was in my cRIO . However the Module ID did not make any sense. I thought the Module ID would have been 9201 for a NI-9201 module. I got a number: 21754370963.
What should the Module ID be?
Solved! Go to Solution.
03-26-2015 10:17 AM
Hello Paul,
The module ID returned by the Module ID property is not the actual module name (ex. 9201). Instead, it returns an ID which you can then match to a specific module as described in the link below.
C Series Module IDs:
http://zone.ni.com/reference/en-XX/help/370984R-01/criodevicehelp/module_ids/
j_bou
03-26-2015 10:51 AM
