Multifunction DAQ
Wiring Unbundle function to Power Vi
Hi
How can you wire the unbundle function to the Power vi. The attached programme of a spectrum analyser has a power vi. How can you set the unbundle function and get the individual elements ,keeping the input time signal to the vi intact?
Mal
(3,418 Views)
Your input to the FFT Power Spectrum is a waveform array. You would first have to use index array to get an element and then wire a Get Waveform Components to the output of that. You cannot use the unbundle or unbundle by name.
(3,411 Views)
Like this Smiley Wink
AdamB
NIUK & Ireland
Applications Engineering Team Leader | National Instruments | UK & Ireland
(3,380 Views)
Hi
Thanks for the help.
Mal
(3,374 Views)
