Multifunction DAQ
Using USB 6002 DAQ to generate waveform using digital output
I am using USB-6002 DAQ multifunction to generate waveform by using digital output. Is it possible to generate a signal using digital output?
(4,152 Views)
Accepted by topic author Shesha12345
You only can generate Digital Waveform(High-Low signal) through "digital output"
If you want to generate an analog output  such as a sine wave, you have to use "analog output"
(4,118 Views)
Okay, Thank you, Sir...
Can I generate PWM with digital output?
(4,113 Views)
Yes, you can generate PWM pulse with digital output.
However, you need to do some coding to apply Duty cycle control.
You also can use Counter Output to generate PWM pulse.
If you use Counter Output, you don't need to do the coding for that.
(4,106 Views)
Can I use one line in digital output to generate PWM?
(4,099 Views)
Yes, you can use it.
(4,092 Views)
Can you please share a code of generating a PWM with digital pin.
Thank you.
(4,090 Views)
