ā11-05-2018 07:55 AM
I am using USB-6002 DAQ multifunction to generate waveform by using digital output. Is it possible to generate a signal using digital output?
ā11-06-2018 11:27 PM
You only can generate Digital Waveform(High-Low signal) through "digital output"
If you want to generate an analog output such as a sine wave, you have to use "analog output"
ā11-07-2018 01:24 AM
Okay, Thank you, Sir...
Can I generate PWM with digital output?
ā11-07-2018 01:34 AM
Yes, you can generate PWM pulse with digital output.
However, you need to do some coding to apply Duty cycle control.
You also can use Counter Output to generate PWM pulse.
If you use Counter Output, you don't need to do the coding for that.
ā11-07-2018 02:32 AM
Can I use one line in digital output to generate PWM?
ā11-07-2018 03:13 AM
Yes, you can use it.
ā11-07-2018 03:19 AM
Can you please share a code of generating a PWM with digital pin.
Thank you.
