Multifunction DAQ
USB device drivers not installed
I have NI USB 6212 device, LabVIEW 2010 and DAQmx device drivers 9.1.5 on Windows 7 (x64). Device is normally recognized on other computer, but not on my computer. When I plugin device, Windows start searching for drivers, but they are not found. Windows Device manager see the device as Unknown device and MAX doesn't see it at all. NI Device monitor is running as well as NI Device Loader.
Any help would be appreciated.
Andrej
(4,544 Views)
It would be best if you tried reinstalling the DAQmx drivers.
Have you tried that?
Regards, Piotr
Piotr Kruczkowski
Certified TestStand Architect
Certified LabVIEW Architect
(4,517 Views)
Accepted by andrej
I don't believe that this is the cause of your problem (since you mentioned that the Windows Device Manager does not see the device), but you should also note that there is a problem in 9.1.5 where devices may not be recognized by MAX; patches are available for 9.1.5  or you can upgrade to DAQmx 9.1.7  or 9.2.2.
(4,505 Views)
I reinstalled DAQmx 9.2.2 drives and solved the problem.
Andrej
(4,470 Views)
Hello...
I have the same problem, but reinstalling NI-DAQmx is not fixing it.
We have used many USB-6212s in many computers and have had few problems.
This particular USB-6212 is recognized in another computer that has the same
motherboard but W7 OS.  But this computer, which has Win XP OS will not
recognize it.  It had DAQmx version 9.1.7 originally.  It wouldn't work.  We removed
DAQmx 9.1.7 and installed DAQmx 9.3.5.  It still doesn't see it.  We have tried
plugging it into other USB ports, having other USB devices present and not present,
and have tried plugging it in via a hub.  Still not working.  We have had
other devices plugged into USB (serial port emulation, flash memory) and they
work fine, so I think this computer's USBs are fine.
Any ideas?  Thanks to everyone who posts!
Halden
(4,099 Views)
