From 01:00 AM CDT Saturday, June 10 - 04:00 AM CDT Saturday, June 10, ni.com will undergo system upgrades that may result in temporary service interruption.
Multifunction DAQ
Triggering analogue output with digital rising edge
I am attempting what I think should be a fairly straightforward operation and experiencing some difficulties...
I am using a DaqCard6715 (analogue output card) connected to a BNC2110 breakout box.
I want to detect a digital rising edge and use it to trigger an analogue output.
My code seems to be doing roughly what I want, but I have a technical difficulty relating to triggering via a terminal (currently PFI3). It appears that the terminal is generating a voltage (or impedance?) so that my digital signal does not register. I think this has something to do with the tristate nature of the terminals, but I cannot find a software command to disable this (only to enable it: DAQmxTristateOutputTerm). Of course my hunch may not be correct.
Here is the set-up and what I have found:
My digital input signal comes in via a BNC connection. The trigger terminals are available via a screw terminal on the BNC2110, so I have used a short wire to connect PFI3 to the user1 (free) BNC input. When I do this, the user 1 terminal suddenly changes its output (according to my oscilloscope) and jumps up 5v. Is this tristate impedance? Now, when I add my external 5v signal, it fails to register.
I know my code is doing something close to what it should, because if instead of using a BNC with its ground, I connect the active wire of my input straight into the PFI3 screw terminal, it triggers as expected. However, even with my very limited understanding of electronics, this doesn't seem like a very reliable way to set up my connections.
I've copied my code below. Any help appreciated!
double Delay = 0;
// Get desired delay in ms
CGetdoubleDialog DDlg;
DDlg.DoubleValue = 0;
if
(DDlg.DoModal() == IDOK)
Delay = DDlg.DoubleValue;
else
return
char String[20];
CString AuditoryTaskChannel = "Dev";
_itoa(m_Timer.m_Card,String,10);
// Gets number for card ^^
AuditoryTaskChannel += String;
AuditoryTaskChannel += "/ao0";
CString TriggerTerminal = "/Dev";
TriggerTerminal += String;
TriggerTerminal += "/PFI3";
long Written;
long S1 = static_cast<long>((Delay*(OutputRate/1000)));
//set up the stimulus buffer
for(long
i = 0; i < OutputLengthLong; i++)
LongOutputBuffer[i] = 0;
if(m_Modality == Auditory)
long j = 0;
for(long i = S1; i < (S1+(OutputRate/100)); i++)
j ++;
LongOutputBuffer[i] = (sin(static_cast<double>(2 * Pi * (j / (OutputRate / Frequency)))) * MaxOutput);
//this is just a sine wave
else
LongOutputBuffer[i] = 5.0;
LongOutputBuffer[S1 + static_cast<long>(OutputRate/100)-1] = 0.0;
//first stimulus presentation
AuditoryTaskHandle=0;
long ReturnValue = DAQmxCreateTask("",&AuditoryTaskHandle);
//this is a function I wrote to return error info
if(ReturnValue != 0)
DAQError();
ReturnValue = DAQmxCreateAOVoltageChan(AuditoryTaskHandle,AuditoryTaskChannel,"",-10.0,10.0,DAQmx_Val_Volts,NULL);
DAQError();
long SamplesToWrite = static_cast<long>(S1 + (OutputRate/100));
ReturnValue = DAQmxCfgSampClkTiming(AuditoryTaskHandle,"OnboardClock",OutputRate,DAQmx_Val_Rising,DAQmx_Val_FiniteSamps,SamplesToWrite);
DAQError();
ReturnValue = DAQmxCfgDigEdgeStartTrig (AuditoryTaskHandle,TriggerTerminal, DAQmx_Val_Rising);
DAQError();
ReturnValue = DAQmxWriteAnalogF64(AuditoryTaskHandle,SamplesToWrite,0,10.0,DAQmx_Val_GroupByChannel,LongOutputBuffer,&Written,NULL);
DAQError();
if (Written != SamplesToWrite)
//not all samples were written
CString TestString = "Samples written: ";
_itoa(Written,String,10);
TestString += String;
AfxMessageBox(TestString,MB_OK);
ReturnValue = DAQmxStartTask(AuditoryTaskHandle);
DAQError();
//wait for task to complete
ReturnValue = DAQmxWaitUntilTaskDone (AuditoryTaskHandle, 10.0);
DAQError();
ReturnValue = DAQmxStopTask(AuditoryTaskHandle);
DAQError();
ReturnValue = DAQmxClearTask(AuditoryTaskHandle);
DAQError();
Message 1 of 1
(2,737 Views)
