Multifunction DAQ
The sampling rate setting in DAQmxCfgSampClkTiming
I would like to set up the sampling rate of PCI-6251with DAQmxCfgSampClkTiming(*taskHandle,"",SampRate,DAQmx_Val_Rising,DAQmx_Val_FiniteSamps,samplesPerChan) for multi AI channels. The 6251 manual says the highest sampling rate for signle channel is 1.25M and 1M for multi-channel. Does that mean I have to set the SampRate to be 1M or it has to be divided by the number of channels (500K if I have two analog inputs?)?
David.
(4,103 Views)
Hi David!  look  here
It seems that you have to divide!
Graziano
(4,096 Views)
Note: I refer to Ayman  post...
(4,094 Views)
Hello David,
Graziano is right, it's 1MS/s divided by the number of channels in the scan list.
Micaela
Micaela N
(4,085 Views)
Thanks guys!
(4,077 Views)
