Multifunction DAQ
The problem of measure voltage
Halo,
Now, i am doing a project. i use the usb 6008 to measure the voltage for the
generator. i use the labview8 to make a progamme.
When i run the progamme, the waveform chart can not show the waveform.But there are no error to occur. How can i set the wareform chart?
i attach the photo for the progamme. Can anybody help me to solve this problem?
Thank.
(3,475 Views)
You must post a screen picture of the front panel, and not of the diagram in order to have an idea of the problem.
Wilfried.
(3,445 Views)
 A waveform graph needs an array of data before it will display anything. Currently you are acquiring a Single sample then placing it on the graph, the result will be effectively no information conveyed. Either change the DAQmx Read to N samples or use a Waveform Chart.  Observe in the following example the DAQmx Read is N Samples with 10 samples acquired before the Waveform Graph is updated.
Now, in this example I am using a Waveform Chart and calling a DAQmx Read Single Sample.
Message Edited by Matthew W on 11-13-2007 10:19 AM
(3,434 Views)
Uh, according to the image, it is a chart.
34,
Is the chart set to autoscale? Also, you are acquiring a waveform data type. Do you see any difference if you switch to DBL datatype? What is the chart history set to?
(3,427 Views)
 To finish my post from earlier:
 This time I am using a DAQmx Read Single Channel Single Sample and displaying on a Waveform Chart.
 Hope this helps!
 MatthewW
 Applications Engineer
(3,426 Views)
Even if there is just one point on the daqmx read, each iteration loop must give a point and trace a graph ?? So it must work like that ?
Is there a problem with the loss of hardware clock set up ?
Wilfried.
(3,422 Views)
