Multifunction DAQ
Excel Problem - move sheet and set axis of 2 plots
I need some help on Excel using ActiveX. I have 2 problems.
1. Move the sheet
I want to change the order of the worksheets. When I create a new Excel file, the order of the worksheet is Sheet1, Sheet2, Sheet3. I would like to change the order to Sheet2, Sheet1, Sheet3.
I have created a vi (attached below, in LabVIEW 8.20) but there is no change in the order of the worksheet. I guess I am missing out something. Could anyone give me some advise??
2. Set the axis of 2 plots
I want to have 2 plots on 1 graph, plot A and plot B. Both plots have different range of values on y-axis. Example, range of y-axis of plot A is 0-10, that of plot B is +/-5. I would like to change the range of y-axis to 0-10. This will means that I am ignoring any y value of plot B that is less than zero.
I hope anyone could give me some light on my problems. Thank you 😃
Regards
Lee
(3,584 Views)
Hi Lee,
For your first question, try it this way:
With regard to your second question, what have you tried so far?
James R.
(3,564 Views)
Hi James,
Could you attach the picture again?? I cannot see the picture.
Sorry about that,
Thank you & Regards
Lee
(3,555 Views)
Hi Lee,
Sorry about that.  I'll post my reply on the other thread
http://forums.ni.com/ni/board/message?board.id=170&message.id=284109
James R.
(3,535 Views)
