Start Trigger Synchronization with USB-6002
Hi all,
I'm trying to implement the Start Trigger Synchronization (Fig. 2) from this article: https://www.ni.com/en/support/documentation/supplemental/21/signal-based-synchronization-of-analog-i... using two analog input channels of USB-6002 and I am getting an error 50103. From what I read, it could be that USB-6002 isn't capable of handling concurrent tasks but when I look at the specs of USB-6002 I cannot find this information. This is my VI:
I made sure to split the total 50kS/s into two (as the 50kS/s is specified as aggregated in the specs of USB-6002). Can anyone help me figure out my mistake here? Thank you very much for your help and take care,
David
(1,443 Views)
Accepted by topic author Omnistic
Put both channels into a single task by specifying "Dev1/ai0:1".  This is a typical restriction across any DAQmx devices I can think of - only 1 AI "timing engine" available per device, so when you need to sample multiple channels, put them all in 1 task.
-Kevin P
(1,422 Views)
To supplement what Kevin has shared, see
Number of Parallel DAQmx Tasks on NI Multifunction Devices
Easily Synchronize and Trigger NI-DAQmx with Channel Expansion
https://tmesystems.net/
(1,407 Views)
Thank you both, very helpful once again. For those interested, this is my corrected VI:
Take care,
David
(1,357 Views)
