SPI with DAQ USB 6210
Hello good day, I'm trying to implement SPI communication with my DAQ USB 6210 as a master are there any VI example already out there?
(2,267 Views)
I think there is no example. Moreover, the DAQ DIO is static, in the sense you could only write one digital state for the pins at a time using API. So, you would have to build the application such that it will write/read appropriate digital levels to the DIO in a timed sequence. One other catch is generating the CLK, you can proceed with static DIO if the CLK duty-cycle is not critical for the SPI slave performance.
Alternatively, you can try the USB-845x series of devices for easy SPI implementation.
Santhosh
Soliton Technologies
(2,240 Views)
Thank you  for the reply.
I will be testing this today,
as soon as I am able to make this work i will mark this reply as an solution thank you.
m.solo
(2,214 Views)
Hi, Unfortunately i am not able to go into the lab due to sickness and have to wait until this pass to continue testing.
regards,
M. Solo
(2,193 Views)
Accepted by topic author m.solo
I managed to sedn data to my microcontroller using this Solution.
put https://forums.ni.com/t5/Multifunction-DAQ/Sending-a-byte-to-a-digital-output-using-a-VI/td-p/356996....
for the moment i am using this to send byte and also reading it.
(2,121 Views)
