Any error introduced by the SCXI terminal block and the shielded cable will be insignificant when compared with the uncertainty of the DAQ board and SCXI module.
That is why the accuracy specs for the terminal blocks and cables are not provided. Also, you would have to include the uncertainty components for the leads, wiring, and transducer if you wanted include the entire system. Adding these factors to you accuracy calculation would have no significant effect on the final calculation, because the errors of the SCXI module and DAQ board are so much greater than that of the copper used in the terminal blocks and cables.
Bill B
